[GRASS-dev] Re: [GRASS-windows] New Wingrass64-Selfinstaller
	(svn-rev39740)
    Helmut Kudrnovsky
    hellik at web.de
    Mon Nov 16 13:13:18 EST 2009
Hi Colin,
>-----Ursprüngliche Nachricht-----
>Von: "Colin Nielsen" <colin.nielsen at gmail.com>
>Gesendet: 16.11.09 17:50:03
>An:  Markus Neteler <neteler at osgeo.org>
>CC: grass-windows at lists.osgeo.org, grass-dev <grass-dev at lists.osgeo.org>
>Betreff: Re: [GRASS-windows] New Wingrass64-Selfinstaller (svn-rev39740)
>Hi Helmut,
>I've just tried the new installer but I'm sorry to tell you that there
>are a couple of major folders missing from it causing GRASS to be
>non-functional. Namely GRASS's bin and lib folders.
there was a typo related to the path to the GRASS bin and lib folders in in my GRASS-Packager.bat-script.
>Also there is anempty directory called "README-Dateien" created which shouldn't be
>there. Please check out the installer scripts and let me know what has
>gone wrong so that we can fix them.
if I save the README.html-file from http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw by firefox, the  "README-Dateien"-folder is also saved. I will remove this folder the next-time I am packaging.
>Finally, since this is not a release candidate version I've been
>creating it in the "DEV6_SVN_REVISION" slot of the installer. If you
>could do it there instead of the RELEASE slot then it will detect the
>older installation and update it accordingly.
because the installer is build on the GRASS64-releasebranch-svn-code (living in C:\OSGeo4W\apps\grass\grass-6.4.0svn) and not on the GRASS65-develbranch-svn-code. but if you can submit your GRASS-Packager.bat- and GRASS-Installer.nsi-script, so we could synchronise the installer.
>Markus, we should probably put the old installer back until this can
>be re-packaged with the missing folders added.
I've build a new installer, also now with the GRASS bin and lib folders. The installer has now about ~ 100MB. I've seen, your earlier self-installers had about ~80MB. the difference in size maybe related to different stuff installed in the osgeo4w-stack?
best regards
Helmut
>Cheers,
>-Colin
>On Sun, Nov 15, 2009 at 5:02 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> there is a new Wingrass64-Selfinstaller, compiled in the osgeo4w-stack at svn-revision 39740 in WinVista.
>> download site:
>> http://grass.osgeo.org/grass64/binary/mswindows/native/
> >at http://trac.osgeo.org/grass/wiki/CompileOnWindows#OpenTickets
> >there are listed several windows specific bug reports. please test.
>> best regards
>> helmut
_____________________________________________________________
DSL-Preisknaller: DSL-Komplettpakete von WEB.DE schon für
16,99 Euro/mtl.!* Hier klicken: http://produkte.web.de/go/02/
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20091116/42ce34fa/smime.bin
