[GRASS-dev] [GRASS GIS] #817: segment lib does not use LFS
trac at osgeo.org
Thu Nov 19 04:37:00 EST 2009
Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: 6.4.0 RCs
Keywords: segment lib with LFS | Platform: All
Cpu: All |
The segment library, managing temporary data stored on disk, does not
support LFS, although file sizes can easily break the 2GB boundary. Fixed
in trunk r39760. All is needed is to add
#compile if LFS Large File Support present:
ifneq ($(USE_LARGEFILES),)
EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endif
to the Makefile. I have also added checks and warnings if LFS is not
available but file size would exceed 2GB. In this case it exits with an
error. Tested on Linux 32 bit (does not apply to Linux 64 bit). Not sure
if this would be an enhancement or if the segment lib is defect because it
tries to read/write to temporary files although it can't, lot's of ugly
warnings that don't help much. Should this change be backported to grass6?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/817>
