[GRASS-dev] [GRASS GIS] #818: v.proj: split_q.c:69: RTreeClassify:
Assertion `!p->taken[i]' failed.
trac at osgeo.org
Thu Nov 19 11:33:09 EST 2009
#818: v.proj: split_q.c:69: RTreeClassify: Assertion `!p->taken[i]' failed.
Reporter: pertusus | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: x86-32 |
On a location with a longitude latitude projection I do a map that
corresponds with the grid, like:
rows_nr=`g.region -g |grep '^rows=' |sed 's/^rows=//'`
r.mapcalc "grid_map=col() + ((row()-1) * $rows_nr)"
r.to.vect input=grid_map out=grid_map_v feature=area
g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:30
ewres: 0:30
rows: 360
cols: 720
cells: 259200
In another location, where the region is:
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
ellipsoid: sphere
north: 4149500
south: -5044500
west: -4368500
east: 4367500
nsres: 1000
ewres: 1000
rows: 9194
cols: 8736
cells: 80318784
I try to project the vector and I get an assertion:
v.proj input="grid_map_v" location="cru_maps"
Building topology for vector map <grid_map_v>...
Registering primitives...
Aborted
In the svn version the file and the assertion is at
lib/vector/rtree/split.c and the bug may be fixed. I can try to reproduce
on the svn version if you give me some directions on how to test in
source.
Ticket URL: <http://trac.osgeo.org/grass/ticket/818>
