[GRASS-dev] Re: [GRASS GIS] #818: v.proj: split_q.c:69:
RTreeClassify: Assertion `!p->taken[i]' failed.
trac at osgeo.org
Fri Nov 20 02:50:35 EST 2009
#818: v.proj: split_q.c:69: RTreeClassify: Assertion `!p->taken[i]' failed.
Reporter: pertusus | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: All | Cpu: All
Changes (by mmetz):
* priority: normal => minor
* platform: Linux => All
* cpu: x86-32 => All
Comment:
Assertion happens only if the whole globe gets reprojected from lonlat to
laea, but not if only the current region extends of laea get reprojected
to laea.
Although it looks like the assertion prevented you from an illegal
reprojection, the assertion should not happen. The changes to the vector
spatial index in grass7 can not be backported because the spatial index in
grass7 has been nearly completely rewritten and is incompatible with the
grass6.x spatial index. The code in question has been replaced by another
algorithm written anew from scratch. In short, this is unlikely to get
fixed in grass6.x.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/818#comment:2>
