[GRASS-dev] bug: g.region vect=3Dmap breaks region
Hamish
hamish_b at yahoo.com
Fri Nov 20 04:24:36 EST 2009
[trac is non-responsive right now so posting here]
In a lat/lon location if you import a lon,lat,z file:
G65> awk '{print $1 "|" $2 "|" $3}' fort.100 | \
v.in.ascii out=fort_100 x=1 y=2 z=3 -t -z
then set the region to match the vector map's bounds:
G65> g.region v=fort_100
the region will be broken:
G65> g.region -p
ERROR: region for current mapset is invalid
line 18: <t-b resol: 1:00:00.0196>
run "g.region"
removing this from the end of $MAPSET/WIND gets you operational again:
top: 4560.63
bottom: -7.39548
cols3: 8
rows3: 9
depths: 4568
e-w resol3: 1:02:32.898867
n-s resol3: 1:03:00.119988
t-b resolution (elevation) obviously shouldn't be in degrees..
thanks,
Hamish
