[GRASS-dev] [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Fri Nov 20 15:05:50 EST 2009
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
The MSys environment included with WinGRASS (WinGRASS-6.4.0svn-
r39740-2-Setup.exe) does not include the bc command used by the r.in.wms
script. This causes the module to fail when trying to import maps from a
WMS service.
GRASS 6.4.0svn (AoCWMS):C:/GRASS/msys/home/Dan > r.in.wms output=roads_15m
mapserver=http://atlas.gc.ca/cgi-bin/atlaswms_en? \
layers=roads_15m format=png maxcols=1024 maxrows=1024 method=bilinear
which: wget: unknown command
which: bc: unknown command
ERROR: 'bc' is required, please install it first
Ticket URL: <https://trac.osgeo.org/grass/ticket/820>
