[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Fri Nov 20 16:20:20 EST 2009
  Reporter:  ddalimonte    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Packaging     |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  r.in.wms
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [ticket:820 ddalimonte]:
 > The MSys environment included with WinGRASS (WinGRASS-6.4.0svn-
 r39740-2-Setup.exe) does not include the bc command used by the r.in.wms
 script. This causes the module to fail when trying to import maps from a
 WMS service.
 > GRASS 6.4.0svn (AoCWMS):C:/GRASS/msys/home/Dan > r.in.wms
 output=roads_15m \
 > mapserver=http://atlas.gc.ca/cgi-bin/atlaswms_en? \
 > layers=roads_15m format=png maxcols=1024 maxrows=1024 method=bilinear
 > which: wget: unknown command
 > which: bc: unknown command
 > ERROR: 'bc' is required, please install it first
 bc can be included in the WinGrass-Installer. i've adapted
 http://trac.osgeo.org/grass/wiki/CompileOnWindows#Pre-builtBinaries with
 bc.
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:2>
