[GRASS-dev] Re: GRASS-dev] Is wxNVIZ supposed to work?
Michael Barton
michael.barton at asu.edu
Fri Nov 20 18:16:58 EST 2009
Glynn,
I just compiled 6.5 Wednesday night and 7.0 trunk last night. wxNVIZ
works fine on both.
I'm using a Mac with OS 10.5.6, Python 2.5.1, and wxPython 2.8.9.2
Michael
On Nov 20, 2009, at 10:05 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Thu, 19 Nov 2009 21:32:10 +0000
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: [GRASS-dev] Is wxNVIZ supposed to work?
> To: grass-dev at lists.osgeo.org
> Message-ID: <19205.47450.333317.639924 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> The wxGUI nviz module is broken for me in both 6.4.0-RC5 and 7.0-head.
> In both cases, selecting "3D view" in the map display window results
> in a segfault in the wxClientDC constructor.
> The last few stack frames are:
> #0 wxWindowDC (this=0xb225028, window=0x0)
> at /var/tmp/portage/x11-libs/wxGTK-2.8.10.1-r1/work/wxPython-
> src-2.8.10.1/src/gtk/dcclient.cpp:294
> #1 0xb7558189 in wxClientDC (this=0xb225028, win=0x0)
> src-2.8.10.1/src/gtk/dcclient.cpp:2473
> #2 0xb755834c in wxPaintDC (this=0xb225028, win=0xb11e420)
> src-2.8.10.1/src/gtk/dcclient.cpp:2436
> #3 0xb6648a49 in _wrap_new_PaintDC (args=0x0, kwargs=0x0)
> at src/gtk/_gdi_wrap.cpp:24778
> #4 0xb7fd7971 in PyCFunction_Call (func=0xa11f7cc, arg=0xae1074c,
> kw=0xb11e420) at Objects/methodobject.c:85
> Enabling debugging, the last message before it crashes is:
> GUI D3/5: GLCanvas.OnPaint()
> Combined, these point to it crashing here (nviz_mapdisp.py:156)
> 153 def OnPaint(self, event):
> 154 Debug.msg(3, "GLCanvas.OnPaint()")
> 155
> 156 dc = wx.PaintDC(self)
> 157 self.SetCurrent()
> 158
> 159 if not self.initView:
> 160 self.nvizClass.InitView()
> 161 self.initView = True
> If I comment out that line (it doesn't need the DC, but apparently
> this is needed on Windows to force the window contents to be marked as
> "valid", otherwise it will just try to repaint it again), it crashes
> within OpenGL:
> #0 0xb41ed346 in glDisable () at ../../../src/mesa/x86/glapi_x86.S:
> 368
> #1 0xb42566a5 in gsd_set_clipplane (num=0, able=0) at gsd_prim.c:1028
> #2 0xb424d5f0 in gsd_cplane_off (num=0) at gsd_cplane.c:129
> #3 0xb423eeba in GS_unset_cplane (num=0) at GS2.c:3156
> #4 0xb4938abc in Nviz_off_cplane (data=0xaef4188, id=0) at
> cplanes_obj.c:51
> #5 0xb493a348 in Nviz_init_data (data=0xaef4188) at nviz.c:42
> #6 0xb42c1c8d in Nviz::InitView ()
> from /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/etc/wxpython/
> nviz/_grass7_wxnviz.so
> #7 0xb42d82dc in _wrap_Nviz_InitView ()
> #8 0xb7eb29e9 in PyCFunction_Call (func=0xa8e784c, arg=0xabdd6ac,
> kw=0xaef4188) at Objects/methodobject.c:116
> My first instinct is that the widget isn't getting "realised" (i.e.
> "made real", meaning that the underlying X window has been created by
> the X server).
> But how is it getting a paint event if it hasn't been realised?
> Ah: mapdisp.py:425 calls OnPaint immediately after creating the
> window:
> 419 if not self.MapWindow3D:
> 420 self.MapWindow3D = nviz.GLWindow(self,
> id=wx.ID_ANY,
> 421 Map=self.Map,
> tree=self.tree, lmgr=self._layerManager)
> 422 # -> show after paint
> 423 self.nvizToolWin = nviz.NvizToolWindow(self,
> id=wx.ID_ANY,
> 424
> mapWindow=self.MapWindow3D)
> 425 self.MapWindow3D.OnPaint(None) # -> LoadData
> 426 self.MapWindow3D.Show()
> 427 self.MapWindow3D.UpdateView(None)
> If I comment out line 425, it gets further before crashing in layout:
> #0 0xb74fa1c3 in wxWindow::DoSetSize (this=0xa4fd178, x=1, y=81,
> width=768,
> height=463, sizeFlags=4)
> src-2.8.10.1/src/gtk/window.cpp:2763
> #1 0xb75fa54f in wxSizerItem::SetDimension (this=0xa39e670,
> pos_=@0x0,
> size_=@0x0)
> src-2.8.10.1/include/wx/window.h:225
> #2 0xb75fe29d in wxBoxSizer::RecalcSizes (this=0xa3b0980)
> src-2.8.10.1/src/common/sizer.cpp:1751
> #3 0xb75fb6a4 in wxSizer::Layout (this=0xa3b0980)
> src-2.8.10.1/src/common/sizer.cpp:880
> #4 0xb75fa2b9 in wxSizer::SetDimension (this=0x1, x=0, y=0,
> width=0, height=0)
> src-2.8.10.1/src/common/sizer.cpp:976
> At which point, I'm lost.
> I think that this is an issue of trying to make calls before the
> toolkit is ready for them. E.g. you can't create a widget then assume
> that it's immediately ready for use; you have to wait for the toolkit
> to report the appropriate event.
> The comment at mapdisp.py:425:
> suggests that it's relying upon the OnPaint method to load the data,
> and the contents of the OnPaint method seem to support that.
> But many of the things which are occuring there rely upon OpenGL
> having been initialised. It's safe to assume that's the case if the
> handler is called in response to an EVT_PAINT event, but it probably
> won't be true if the program calls it itself as soon as the widget has
> been created.
> However, removing that call means that the nviz library and the binary
> grass7_wxnviz module won't have been initialised, and UpdateView(),
> OnSize() etc assume that they have. IOW, the code both needs to call
> OnPaint() at that point but cannot call OnPaint() at that point.
> The only solution is to check that initialisation has happened before
> relying upon it. Being able to force initialisation as soon as the
> widget is created would make life simpler, but unfortunately it isn't
> possible; you have to wait until the widget is ready.
