[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Sat Nov 21 05:20:30 EST 2009
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Resolution: | Keywords: r.in.wms
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:13 neteler]:
> Replying to [comment:12 hellik]:
> > Replying to [comment:10 hellik]:
> > > Replying to [comment:8 hamish]:
> > > > * wget can be replaced by curl if it is installed; there's a
flag. But really we/msys should ship a copy of wget in our windows
package. (fwiw Mac ships curl not wget)
> Why should we then ship wget if osgeo4w already ships curl?
> > wget can be download as pre-built-binary from the gnuwin32-website and
integrated in the windows-package
> Since curl is there is looks more reasonable to get that used at this
point. Apparently the test fails:
> # check if we have wget or curl
> if [ ! -x "`which wget`" ] ; then
> if [ ! -x "`which curl`" ] ; then
> g.message -e "Either 'wget' or 'curl' is required, please
install one first"
> exit 1
> else
> g.message -v "Using CURL for downloading data."
> USE_CURL=1
> fi
> else
> g.message -v "Using WGET for downloading data."
> USE_WGET=1
> fi
> Perhaps the which magic is non-functional with Msys?
> Helmut: could you take out the test in the script and just set
> USE_CURL=1
> to see what happens then?
> Markus
i've unset the curl/wget-check and set USE_CURL=1. bash, bc is in the
osgeo4w/msys-stack:
again the same error:
r.in.wms output=elevation_meters mapserver=http://wms.jpl.nasa.gov/wms.cgi
layers=us_ned styles=real -o
c:/OSGeo4W/apps/grass/grass-6.4.0svn/scripts/r.in.wms: eval:
line 1: unexpected EOF while looking for matching `''
line 2: syntax error: unexpected end of file
Calculating tiles
c:/osgeo4w/apps/grass/grass-6.4.0svn/scripts/r.tileset:
[0]=SOURCE_PROJ: command not found
[1]=1: command not found
[2]=DEST_PROJ: command not found
[3]=SOURCE_TO_DEST: command not found
[0]=DEST_PROJ: command not found
[1]=SOURCE_PROJ: command not found
[2]=1: command not found
[3]=DEST_TO_SOURCE: command not found
(standard_in) 2: parse error
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>:
projection initialization failure
cause: Unknown error
program abnormally terminated
ERROR: Problem running cs2cs. <Using from definition: >
ERROR: r.tileset failure
ERROR: wms.request failure
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:14>
