[GRASS-dev] undefined reference to `db_set_connection'
Jarosław Jasiewicz
jarekj at amu.edu.pl
Wed Nov 25 10:49:00 EST 2009
Hi
I try to write function which will create temporary table to store
data.... (Grass65)
#include <grass/gis.h>
#include <grass/dbmi.h>
#include <grass/Vect.h>
int create_table (void)
dbConnection conn;
dbDriver *driver;
dbHandle handle;
dbString table_name, db_sql, val_string;
char *cat_col_name;
char buf[1000];
/* string to db */
db_get_connection(&conn);
G_debug(1, "driver: %s", conn.driverName);
G_debug(1, "database: %s", conn.databaseName);
during compilation I recive error:
undefined reference to `db_get_connection'
what is wrong?
BTW: I need table only but not vector file so I use this instead of
Vect_default_field_info()
thanks for any help
Jarek
