[GRASS-dev] Re: r39856 - Do not fail to start gis.m in XY
location due to missing proj info
Maris Nartiss
maris.gis at gmail.com
Mon Nov 30 07:43:31 EST 2009
Hello,
in short - Your analysis of code is wrong. Break interupts while cycle
(@478) and thus $prj is unset but used @490.
Maris.
2009/11/30, Hamish <hamish_b at yahoo.com>:
> Hi,
> wrt r39856,
> a few lines above the new work-around XY locations are specifically
> tested for & dealt with. the `break` should ensure that XY loc'ns
> never reach the patched code.
> is the real problem that the "XY location (unprojected)" text has
> been translated so the match no longer works?
> if so, and it is ok to have that be translated (I'm not sure it
> is), should we change it to run g.region -p and check that the
> projection code == 0 as a steadier target?
> or is the XY compare otherwise busted?
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
