[GRASS-dev] Using GRASS in long running and multithreaded
applications Was: Re: The tomcat shut down ...
Soeren Gebbert
soerengebbert at googlemail.com
Thu Oct 1 12:54:49 EDT 2009
Hi Glynn,
thanks a lot for your response.
After reading some documentation and asking "silly" questions to
my poor informatics colleagues, i understand the concept of thread local and
the setjmp()/longjmp() approach a bit better.
I would suggest to add longjmp() to G_fatal_error().
It should be set at runtime by an application if longjmp() should be
chosen or not.
So G_fatal_error() will either call longjmp() or exit().
The setjmp() code goes into the application which calls the grass
library functions,
except if nested setjmp()/longjmp() calls are needed in grass to clean
up data, or
to close open file descriptors.
The linux threaded errno definition scared me, so i have chosen a
different approach.
We define thread local support and two extern variables in gis.h to
choose at runtime if
G_fatal_error() will call exit() or longjmp() and to add thread local support.
Example which works for me in my test code:
/*Thread local and setjmp() exception support*/
#include <setjmp.h>
#ifdef WIN32
#define Thread __declspec( thread )
#else
#define Thread __thread
#endif
extern Thread jmp_buf G_stack_buffer; /*to save the most important
CPU register for each thread*/
extern int G_long_run; /*Set to 1 to choose the setjmp() version of
G_fatal_error()*/
The G_long_run variable will be initialized in gisinit.c and so the
G_stack_buff:
int G_long_run;
void G__gisinit(const char *version, const char *pgm)
const char *mapset;
if (initialized)
return;
G_long_run = 0;
The application has to set G_long_run right after
calling G_gisinit() from a single thread (i.e: a singleton).
Now we need to patch error.c to use longjmp() or exit():
void G_fatal_error(const char *msg, ...)
va_list ap;
va_start(ap, msg);
vfprint_error(ERR, msg, ap);
va_end(ap);
if(G_long_run == 1)
longjmp(G_stack_buffer, 1);
else
exit(EXIT_FAILURE);
The C++ application code may look like this:
extern "C" {
#include <grass/gis.h>
int G_long_run;
vtkGRASSInit::vtkGRASSInit() {
G_gisinit("vtkGRASSBridge");
// Set the long run variable to provide long run support in grass libraries
G_long_run = 1;
/*Open a vector map*/
if(!setjmp(G_stack_buffer))
if (1 > Vect_open_new(&this->map, name, with_z))
fprintf(stderr, "class: %s line: %i Unable to open vector map <%s>.",
this->GetClassName(), __LINE__, name);
return false;
} else {
this->GetClassName(), __LINE__, name);;
return false;
That's all.
Is this approach ok or to simple or just naive? :)
If this is ok, i would like to test this approach to identify possible
calls in libgis, libraster and libvector.
Additionally i will try to make most of the static variable thread local.
Best regards
Soeren
2009/9/27 Glynn Clements <glynn at gclements.plus.com>:
> Soeren Gebbert wrote:
>> > I'm not suggesting making all of the functions take a pointer to the
>> > state as a parameter, just making it thread-local.
>> Ok.
>> To my shame i have to admit that i never heard of the thread-local
>> mechanism before.
>> After a quick look at wikipedia i understand the principal and it sounds great!
>> This will speed up things a lot.
>> I guess we need to use the pthread version of thread-local to support
>> other compiler than gcc and windows too?
> You would need to conditionalise it. The usual mechanism is like that
> used for errno. In a single-threaded implementation, it's just a
> variable. In a multi-threaded implementation, it's a macro which
> expands to (*errno_location()), where errno_location() retrieves the
> address using pthread_getspecific().
>> > However, the error handling is probably a bigger issue. Pushing error
>> > handling onto the modules isn't an acceptable solution.
>> Indeed. This was the next issue i would like to talk about.
>> > Simply allowing the fatal error handler to longjmp() out then resume
>> > using the GRASS libraries would be non-trivial, as you would have to
>> > repair any inconsistencies in the library state.
>> Is there an alternative to longjmp() and setjmp()?
> Not really.
>> It seems to be quite complex, the man page warns about the usage.
>> And i never used it before.
> longjmp() is conceptually similar to raising an exception in C++,
> while setjmp() is equivalent to establishing a try/catch block.
> The details are quite simple if you understand how C is implemented in
> terms of machine code. setjmp() essentially saves the most important
> CPU registers (including the program counter, stack pointer, and frame
> pointer), while longjmp() restores them. So setjmp() records the
> current execution state while longjmp() restores it (similar to
> save/load in a game).
> Most of the complexities and warnings relate to potential interactions
> with optimisation. Primarily, local variables in the function which
> calls setjmp() aren't guaranteed to be restored to the correct value
> by longjmp(). gcc warns you if this might occur. Using the "volatile"
> qualifier can help here.
> The other caveat is that you can't "wrap" setjmp(). The saved state
> ceases to become valid once you leave the function which called
> setjmp(), so you can only call longjmp() from within a "descendent" of
> the function which calls setjmp().
> In terms of using it to recover from a fatal error, the usage would be
> something along the lines of:
> jmp_buf save;
> int my_handler(const char *msg, int fatal) {
> print_error(msg, fatal);
> longjmp(save, 1);
> return 0; /* can't happen; longjmp() doesn't return */
> void main_loop(void) {
> volatile int done;
> G_set_error_routine(my_handler);
> for (done = 0; !done; ) {
> if (setjmp(save) != 0)
> continue; /* fatal error happened */
> done = do_next_action();
> G_unset_error_routine();
> A common idiom is to call setjmp() in the top-level loop, at the
> beginning of each "action", and have the fatal error handler call
> longjmp(). If an error occurs during the execution of an action, the
> longjmp() will jump back out to the main loop which can then process
> the next action.
> An example can be found in lib/driver/main.c (in 6.x), where setjmp()
> and longjmp() are used to to recover from SIGPIPE, so that the monitor
> doesn't terminate if the client terminates prematurely.
>> > Allowing G_fatal_error() to return is enough work that it can probably
>> > be ruled out. Apart from changing every single call (I count 520
>> > references in lib/*), almost every public function would need two
>> > versions: one which returns an error code and one which treats errors
>> > as fatal (i.e. only returns upon success).
>> 520 calls are indeed a lot. The raster and gis libraries all together
>> have 70 calls and
>> the vector and db libraries have 190 calls.
>> Glynn, if you can point me to a concrete implementation concept, i
>> would like to start to patch the gis, raster, vector and db libraries
>> in grass7.
>> Maybe we can use signals to set an error variable in the resume error function?
> The least invasive approach is to perform clean-up before calling
> G_fatal_error(), so that subsequent operations don't crash GRASS, and
> rely upon the application registering an error handler which
> longjmp()s out.
> G_fatal_error() can't be made to return, as that would break all of
> the modules which use it. And library functions which don't return on
> error can't be changed to return.
> You *could* replace existing functions with a wrapper around a version
> which returns on error. The original function would be modified to
> return a status indication upon error, and the wrapper would just call
> the modified version and call G_fatal_error() in the event of an
> error. Functions which want to handle the error themselves would call
> the lower-level function.
> The main problems here are:
> 1. The sheer number of such functions.
> 2. The functions may rely upon other functions which currently call
> G_fatal_error(). So you would have to make similar changes to the
> underlying functions, then modify the calling function to allow for
> the fact that these functions can fail.
> 3. Reporting errors where the error message includes data from local
> variables. One option here would be to give the underlying function a
> "fatal" parameter, and add a G_error() function which takes an extra
> parameter indicating whether to terminate.
> All things considered, making it safe to longjmp() out of the fatal
> error handler is would be a lot less work.
>> > The main issue for concurrent reading is that the raster library
>> > caches the current row, so that upscaling doesn't read and decode each
>> > row multiple times. That's problematic if you want multiple threads
>> > reading the same map.
>> Reading single raster maps in different threads is just great. Everything else
>> is like icing on the cake.
> BTW, you can read the same map from multiple threads provided that you
> open it once for each thread.
> r.mapcalc only opens each map once, but it uses a mutex to prevent
> concurrent access.
