[GRASS-dev] Some wxGUI tests on Windows
Glynn Clements
glynn at gclements.plus.com
Sat Oct 3 00:27:06 EDT 2009
Jarek Jasiewicz wrote:
> > - r.shaded.relief doesn't show any error but the result is completely NULL.
> > Perhaps due to the fact that it is a shell script? If so, I would suggest
> > to add a Windows test and to bail out rather than continue unless it
> > is substituted with the Python version (6.4.1?).
> Is there some objectives to replace r.shaded.relief with C code?.
What would be the point? The script is essentially a single r.mapcalc
expression.
