[GRASS-dev] [GRASS GIS] #773: r.in.gdal unclean import of southern
UTM zone
trac at osgeo.org
Sun Oct 4 21:21:01 EDT 2009
#773: r.in.gdal unclean import of southern UTM zone
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-develbranch6
Keywords: r.in.gdal, utm | Platform: Unspecified
Cpu: Unspecified |
after bringing in a GeoTiff georef'd to UTM 48S with r.in.gdal I get a
errors when trying to open the map:
WARNING: Raster map <Multichrom.red at user1> is in different zone
(-48) than current region (48)
WARNING: Unable to open raster map <Multichrom.red at user1>
ERROR: Unable to open raster map <Multichrom.red>
location was created manually using the text based g.setproj.
r.in.gdal gave the "projection parameters appear to match" message.
G65> g.region -p
projection: 1 (UTM)
zone: 48
G65> g.proj -p
-PROJ_INFO-------------------------------------------------
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : utm
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
south : defined
zone : 48
GRASS 6.5svn,
GDAL 1.5.2-3~bpo40+1 on Debian/etch.
gdalinfo:
Coordinate System is:
PROJCS["WGS 84 / UTM zone 48S",
GEOGCS["WGS 84",
DATUM["WGS_1984",
manually editing the $MAPSET/cellhd/ files to make the zone: line positive
"fixes" it.
should the lib fn's automatically translate a cellhd negative zone number
into PROJ_INFO's zone:+south: keys? cellhd can not use "south:" for utm
zone as that's already used for the raster's southern bound. Should those
two be allowed to get out of sync or is it less bad to just ignore the
sign of the zone number in the raster's cellhd? If lib/gis/rd_cellhd.c is
modified to allow negative zone numbers note that the uninit'd value of -1
would have to be adjusted to -255 or something outside the legal range.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/773>
