[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS:
$GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Tue Oct 6 02:36:57 EDT 2009
#580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by cmbarton):
Replying to [comment:11 glynn]:
> Replying to [comment:10 cmbarton]:
> > So far nothing works. We did up the Python script the way it is
suggested in the WIKI and it works fine on Linux and Mac. It either does
nothing or hangs before launching on Windows. The farthest we've gotten is
to get the error that the script does not generate an XML interface-
description. My interpretation is that python parser work on Linux and Mac
but not on Windows from the command line.
> On Windows, 6.4's g.parser explicitly invokes the script via $GRASS_SH.
Obviously this won't work for Python scripts.
Does this mean that it is only expecting shell scripts in Windows? What
happens on other platforms (since Python does run without problems in
Linux and on Mac)?
> FWIW, Python scripts work in Windows in 7.0, whether the script is in
the path or not (once PYTHONPATH has been set; Init.bat doesn't set this).
> The biggest difference between the two is that in 7.0, the
grass.script.parser() Python function uses "g.parser -s", which eliminates
the need to re-execute the script. It may be worth back-porting this
feature to 6.x (the existing behaviour is still available for use by shell
scripts).
Seems like that would be a very good idea, if it means that you can run
something besides shell scripts in a Windows environment.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:12>
