[GRASS-dev] Re: [GRASS GIS] #553: wx and tcltk GUI: changing
 default GUI returns error
    trac at osgeo.org
    Wed Oct  7 21:30:30 EDT 2009
#553: wx and tcltk GUI: changing default GUI returns error
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wxgui gis.m
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:10 cmbarton]:
 > Does anyone know how to solve this scripts issue for Windows? I'm happy
 to implement something but don't understand how to fix this. It seems to
 me that it is something that needs to be done somewhere outside the GUI.
 If so, we should probably change the "component" to whatever component is
 the right place to fix Windows ability to read these scripts.
 The core issue is that Windows decides how to "run" scripts via the
 extension, not the shebang. If you want to support the most general case,
 all scripts must have an appropriate extension, e.g. .sh for Bourne shell
 scripts. Even then, we're dependent upon the file associations being set
 correctly (on Unix, we're dependent upon /bin/sh being a Bourne shell, but
 that's a much safer assumption).
 We can get more limited support either by relying upon MSys or by
 implementing similar emulation ourselves (i.e. writing a utility to
 identify whether a command is an exe or a script and invoking the
 appropriate interpreter).
 Either way, g.parser needs to be changed to match.
 One option is to back-port the -s switch used by Python scripts, and to
 add similar functionality for Bourne-shell scripts (i.e. write out
 environment settings in a form that can be "eval"d). But that would
 require changing the g.parser boilerplate in existing shell scripts.
 Aside from that, when invoking commands via subprocess.Popen, ensure that
 you use shell=True on Windows. Without that, it will only work for
 binaries (.exe and .com), not for scripts (which includes .bat files).
Ticket URL: <https://trac.osgeo.org/grass/ticket/553#comment:11>
