[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show
all datum transform opts
trac at osgeo.org
Sun Oct 11 04:39:00 EDT 2009
#785: wx location wizard: doesn't show all datum transform opts
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: location wizard
Platform: Linux | Cpu: x86-64
Comment (by hamish):
* datum name now makes it to 'g.proj -p', great.
some fine tuning:
* search by code works well. if I search for the "wgs" datum I see a
bunch of repeats.
* trying to make a UTM location:
File "/home/hamish/dev/grass/svn/grass65/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_modules/location_wizard.py", line 1573, in
OnEnterPage
self.lproj4string.SetLabel(self.parent.CreateProj4String())
gnu/etc/wxpython/gui_modules/location_wizard.py", line 1983, in
CreateProj4String
proj4string = '+proj=%s +zone=%s' % (utm, utmzone)
NameError: global name 'utm' is not defined
this needs to be undone:
@@ -1979,10 +1981,12 @@
proj4string = '+proj=longlat'
elif proj == 'utm':
- proj4string = '+proj=%s +zone=%s' % (proj, utmzone)
+ proj4string = '+proj=%s +zone=%s' % (utm, utmzone)
if utmhemisphere == 'south':
- proj4string += ' +south'
+ proj4string += '+south'
else:
proj4string = '+proj=%s ' % (proj)
* could it ask for the datum transform before getting to the summary
page? the summary page still lists the +dx +dy +dz proj4 terms which will
not be used.
* text line for datum transform option # 1 overflows the right edge of
the window (..."(May not be optimum for older [chop]")
* "Datums (select to see descriptions)" - nitpicky: It should probably be
"Transform Parameters:" not "Datums:".
* could the transform pulldown list be by +proj4 term instead of by
number? The number is internals which doesn't need to be exposed. Suggest
adding '+' to the start of the proj4 term.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/785#comment:10>
