[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show
all datum transform opts
trac at osgeo.org
Sun Oct 11 12:09:56 EDT 2009
#785: wx location wizard: doesn't show all datum transform opts
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: location wizard
Platform: Linux | Cpu: x86-64
Comment (by cmbarton):
Replying to [comment:11 hamish]:
> there is still some work to be done I'm afraid.. a g.setproj session
should give some guidance.
> for other projections it is not asking all it needs to. e.g. LCC, TMerc
never asks for lat_0, lon_0, etc.
Could you explain?
> see general/g.setproj/proj-parms.table for a list of questions which
need to be asked (or are hardwired) for a given projection.
I'll take a look. I want to try and fix the prior issues first.
Michael
> (see proj-desc.table to convert those to +proj4 terms)
> the wizard should also probably ask what units you want (see proj-
units.table)
> Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/785#comment:15>
