[GRASS-dev] Re: [GRASS-user] grass-6.4.0RC5 and wx-python
Martin Landa
landa.martin at gmail.com
Mon Oct 12 16:20:50 EDT 2009
2009/10/12 Glynn Clements <glynn at gclements.plus.com>:
> Obviously, if the "import wxversion" fails, wxversion.VersionError
> isn't going to resolve.
> FWIW, the same problem exists in trunk.
> The code should probably look something like:
> try:
> import wxversion
> try:
> wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
> except (ValueError, wxversion.VersionError), e:
> except ImportError, e:
right, hopefully fixed r39494.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
