[GRASS-dev] problems with datum parameters tables
Michael Barton
Michael.Barton at asu.edu
Wed Oct 14 12:20:07 EDT 2009
Thanks much Glynn. This is helpful. There is no urgency on the
parameters without descriptions right now since nothing seems to use
these, but we can't use them in the future without some kind of
description to parse.
Michael
On Oct 14, 2009, at 6:22 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> I'm working on the GUI location manager and have run into a couple of
>> irregularities in a couple of the projections parameters files. I'm
>> sending this to the list instead of keeping it in the location wizard
>> track ticket because they are a more general issue that will affect
>> projection/location creation by other means too.
>> In proj-parms.table, the entry for "GEOS" is incorrect. There should
>> be 3 subentries for each entry: projection code, projection
>> description, and required parameters. However, GEOS is missing the
>> projection description.
>> GEOS:HEIGH=ask,35800000.0;LON0=ask,20.0
> Well caught.
>> GEOS is the only incorrect formatted entry in the file. It also is
>> NOT
>> in the datums.table file. So either it should be:
>> 1) deleted from proj-parms.table, or
>> 2) added to datums.table and a descriptive field added in proj-
>> parms.table
>> Because it cannot be correctly parsed, I'll just skip it in the GUI
>> location wizard. But if we are going to use this projection, it needs
>> to be corrected in the 2 tables.
> The history behind that entry:
> http://lists.osgeo.org/pipermail/grass-dev/2006-December/028324.html
> http://trac.osgeo.org/grass/changeset/22186
> IOW, it should probably be there, but should have the right number of
> fields (ideally an actual description, but an empty description is
> better than invalid syntax).
> [I see that this has now been done.]
>> Also, in the proj-desc.table, several entries are incorrectly
>> formatted. None of them are used by the proj-parms.table and so they
>> probably should be removed from the proj-desc.table file. All are
>> missing their description fields that are needed so that they can be
>> read by a user. They are:
>> GUAM:bool:guam:
>> OALPHA:lat:o_alpha:
>> OLAT1:lat:o_lat_1:
>> OLAT2:lat:o_lat_2:
>> OLON1:lon:o_lon_1:
>> OLON2:lon:o_lon_2:
>> OLONC:lon:o_lon_c:
> These are correctly formatted; they just have an empty description.
> I removed the data from the g.setproj source code and placed it in
> external files. Any descriptions (or lack of them) are as found in the
> original g.setproj source code.
> If you want to add descriptions, you'll need to examine the PROJ
> source code. However, some parameters may have entirely different
> meanings for different projections.
> Glynn Clements <glynn at gclements.plus.com>
