[GRASS-dev] Re: [GRASS GIS] #783: r.watershed fails on wingrass
trac at osgeo.org
Wed Oct 14 14:17:16 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.watershed, wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by mmetz):
Replying to [comment:10 glynn]:
> Does it work (with the quotes) if you add ".exe" to the end of the
command name and/or use G_convert_dirseps_to_host()?
Nope. As long as there is any quote at the very beginning of the command
string, system and G_system() remove that quote, search for the last
quote, remove everything after the last quote (I tried putting flags at
the end, they don't get quotes), and add their own quotes to the beginning
and end (locale-specific, double quotes on my German XP version, single
quotes on English XP version).
In order to avoid both quotes and spaces, the only alternative I could
find was adding the path to r.watershed.[ram|seg] to PATH or
r.watershed.[ram|seg] to something that's in PATH. But
r.watershed.[ram|seg] is currently not in PATH in order to hide them from
users IIRC.
Another possibility could be to rewrite r.watershed and put
r.watershed.[ram|seg] into a local library like e.g. r.li.daemon?
In short, I could not find a way to make it work with quotes on windows
(BTW, neither osgeo4w nor mingw-w64 with XP 64bit).
> I suspect that eliminating the quotes will mean that it fails if GRASS
is installed in a directory which contains spaces, and without
Administrator privileges you may be unable to install GRASS in a directory
which doesn't contain spaces.
Ticket URL: <https://trac.osgeo.org/grass/ticket/783#comment:11>
