[GRASS-dev] Reading Float64 data as double using r.in.gdal
Upendra Dadi
udadi at gmu.edu
Thu Oct 15 12:53:36 EDT 2009
I found this in the r.in.gdal documentation:
"Float32 and Float64 type bands are translated as GRASS floating point cells (but not double precision ... this could be added if needed)"
I guess r.out.gdal can translate DCELL_TYPE into Float64. Why is Float64 translated to FCELL_TYPE instead DCELL_TYPE? What is the reason for the discrepancy? What should I do to allow transformation of Float64 into DCELL_TYPE?
In main function(using C) for r.in.gdal, there is a function named importBand():
eRawGDT = GDALGetRasterDataType(hBand);
switch (eRawGDT) {
case GDT_Float32:
case GDT_Float64:
data_type = FCELL_TYPE;
eGDT = GDT_Float32;
complex = FALSE;
break;
Would re-writing this to the following(and making some changes in the subsequent code) wouldn't work?:
case GDT_Float32:
eGDT = GDT_Float32;
complex = FALSE;
break;
case GDT_Float64:
data_type = DCELL_TYPE;
eGDT = GDT_Float64;
complex = FALSE;
break;
Any suggestions are greatly appreciated. Thank you.
Regards,
Upendra
