[GRASS-dev] r.sim.water working?
cgnicholas at alamedanet.net
Sat Oct 17 03:49:36 EDT 2009
>From a previous post I realize r.terraflow isnt working in 6.4 yet.., so
thought I would try a dumbed-down-DEM with r.sim.water ... DEM, mask,
slope, aspect, etc look good; everything seem to run, but...no outputs
are generated.... hmmm...?
( I can take this to users' list if this is the wrong place, but seems a
lot of things are in motion here...)
thanks in advance!
Chris
[Raster MASK present]
GRASS 6.4.0RC5 (Haiti):~/tmp > r.sim.water -t elevin=DEM100m at PERMANENT
dxin=dx at PERMANENT dyin=dy at PERMANENT rain_val=50 infil_val=0.0
manin_val=0.1 depth=water_depth at PERMANENT disch=water_discharge at PERMANENT
err=error_map at PERMANENT niter=10 outiter=2 diffc=0.8 hmax=0.3 halpha=4.0
hbeta=0.5 --overwrite
default nwalk=68487324, rwalk=68487324.000000
Min elevation = 1.00 m
Max elevation = 3109.00 m
Mean Source Rate (rainf. excess or sediment) = 0.000002 m/s or kg/m2s
Mean flow velocity = 0.628966 m/s
Mean Mannings = 0.606325
Number of iterations = 3 cells
Time step = 39.75 s
GRASS 6.4.0RC5 (Haiti):~/tmp > g.gisenv
LOCATION_NAME=Haiti
MAPSET=PERMANENT
DIGITIZER=none
GISDBASE=/home/cgn/GRASS
MONITOR=x7
GRASS_GUI=tcltk
GRASS 6.4.0RC5 (Haiti):~/tmp > g.region -p
projection: 1 (UTM)
zone: 0
datum: wgs84
ellipsoid: a=6378137 es=0.006694379990141316
north: 2338174.90627377
south: 1879574.90627377
west: 499985.21620627
east: 1246685.21620627
nsres: 100
ewres: 100
rows: 4586
cols: 7467
cells: 34243662
GRASS 6.4.0RC5 (Haiti):~/tmp > g.list type=rast
raster files available in mapset <PERMANENT>:
DEM100m aspect dx dyy
slope_steepness
MASK basinid dxx half_basins streams
accum curvature dxy slope tcurvature
asin_visual drainage_dir dy slope_length
