[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show
all datum transform opts
Michael Barton
michael.barton at asu.edu
Sun Oct 18 14:01:25 EDT 2009
Trying to make this more readable in the tracker made it turn out
exceptionally ugly in the list. Sorry.
Michael
On Oct 18, 2009, at 10:57 AM, GRASS GIS wrote:
> #785: wx location wizard: doesn't show all datum transform opts
> Reporter: hamish | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: critical | Milestone: 6.4.0
> Component: wxGUI | Version: svn-develbranch6
> Resolution: | Keywords: location wizard
> Platform: Linux | Cpu: x86-64
> Comment (by cmbarton):
> Replying to [comment:26 hamish]:
>> just trying it out.. almost there.[[BR]]
> [[BR]]
> Thanks for testing so quickly.[[BR]]
> [[BR]]
>> * for hardcoded "noask" values could the text boxes be greyed out?
> [[BR]]
> [[BR]]
> Yes. Easy
> [[BR]]
> [[BR]]
> (e.g. NZMG, Lat/Lon's +lat_0,+lon_0 [could that 0,0 for LL just be
> removed
> from proj-parms.table?])[[BR]]
> [[BR]]
> No. If it has the wrong number of fields to parse, it won't get
> parsed.
> [[BR]]
> [[BR]]
>> * "datum :" does not get set in resulting PROJ_INFO file (#784) if
> selecting terms manually. This was fixed for a short time last week
> & then
> broke again a few days ago. (try running `g.region -p`) Creation using
> EPSG code works.[[BR]]
> [[BR]]
> This is a g.proj issue
> [[BR]]
> [[BR]]
>> * Expand boolean from N/Y to No/Yes. e.g. UTM Southern Hemisphere
> question the default is "N" which can also be "North".[[BR]]
> [[BR]]
> I understand the point, but 'No' is also a common abbreviation for
> north
> in some English dialects. So I can make the change, but I'm not sure
> that
> this helps. IIRC, g.setproj uses y/n.
> [[BR]]
> [[BR]]
> Better yet: figure out how to have it be 'Hemisphere: North|
> South'[[BR]]
> [[BR]]
> Won't work because PROJ4 doesn't recognize it. I could do a bunch of
> hard
> coding of course, but the idea is to not have to change the
> interface if
> the underlying module and table contents change.
> [[BR]][[BR]]
>> * For UTM, could 1-60 pulldown list be a constrained value spinbox
> instead?[[BR]]
> [[BR]]
> Why is a spinbox better than a pulldown where you can quickly get to
> the
> number? I could just make it an open text control, but the choicebox
> ensures that a legal value is chosen.[[BR]]
> [[BR]]
>> * Could datum transform list selection popup be integrated into the
> wizard [<Back] [Fwd>] pages, or at least be given the same window
> height x
> width? It seems a bit out of place. [[BR]]
> [[BR]]
> No. The most reliable way to get this is have g.proj datumtrans=-1
> spit it
> out. [[BR]]
> It comes out as a list of 3-4 lines per transform. I could wrap them
> all
> together (i.e., into a paragraph that wraps), but they seem easier
> to read
> in the vertical format. If most people like the paragraph format, it
> is
> easy enough to do.[[BR]]
> Style wise, it matches similar kinds of list controls in the wizard.
> [[BR]]
> [[BR]]
> Better yet: could it have a radio button list like the Tcl/Tk
> version (try
> EPSG:27200). [[BR]]
> [[BR]]
> Why radiobuttons over the select the list item? This adds even more
> whitespace to the left of the list item. I'm trying to keep it as
> compact
> as possible while still readable. There is quite a bit of text in
> some of
> the transform descriptions.[[BR]]
> [[BR]]
> Also same as the Tcl version it should have a "continue without"
> option as
> well.[[BR]]
> [[BR]]
> Good point, we need a default "0" transformation. Easy enough to do.
> [[BR]]
> [[BR]]
>> * on the "Specify geodetic datum" page, could the Description
>> column be
> made a bit wider by default? it's the long string and ellipsoid is the
> short one.[[BR]]
> [[BR]]
> The only way is to make it 3rd in the list. Not hard to do, but will
> require rewiring things that look for it in 2nd place.
> [[BR]]
> [[BR]]
>> * "Choose EPSG code" search is still a bit weird (need to reload to
> start a new search)[[BR]]
> [[BR]]
> I think I can make it work like the other searches now so that it
> automatically looks in all fields with a single control.
> [[BR]]
> [[BR]]
>> thanks,
>> Hamish[[BR]]
> [[BR]]
> Glad it's getting closer.[[BR]]
> [[BR]]
> Michael
> Ticket URL: <https://trac.osgeo.org/grass/ticket/785#comment:27>
> GRASS GIS <http://grass.osgeo.org>
