[GRASS-dev] Re: [GRASS GIS] #784: wx location wizard: fails to set
datum
trac at osgeo.org
Sun Oct 18 21:19:54 EDT 2009
#784: wx location wizard: fails to set datum
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by cmbarton):
* component: wxGUI => Projections/Datums
Comment:
The GUI creates a location using g.proj -c. So if a datum does not get
set, it is a problem with g.proj AFAICT. This is indeed serious and needs
fixing. I'm changing it from wxGUI to projections/datums in the hopes of
getting it fixed.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/784#comment:6>
