[GRASS-dev] Re: [GRASS-user] Remote Sessions with NX (NoMachine)???
Glynn Clements
glynn at gclements.plus.com
Mon Oct 19 09:16:04 EDT 2009
[CC to grass-dev]
Lawrence Houston wrote:
> While running Sessions Remotely using NX (www.NoMachine.com) I can have
> problems using GRASS's XDRIVER: With NX 2.1 the XDRIVER successfully
> displays Raster Images, although with NX 3.X the XDRIVER Window remains
> "Blank" without the Raster Image being "Visible"!!! Would prefer to use
> newer versions of NX, although without being able to view Raster Images
> within GRASS that is not really an "Option"... Is there a "Solution" for
> GRASS Users using NX 3.X???
I think that this change might be necessary, although I don't know if
the problem which you report is related to it.
--- display/drivers/XDRIVER/Respond.c (revision 39378)
+++ display/drivers/XDRIVER/Respond.c (working copy)
@@ -4,6 +4,7 @@
void XD_Respond(void)
+ XSetWindowBackgroundPixmap(dpy, grwin, bkupmap);
XClearWindow(dpy, grwin);
XSync(dpy, 1);
needs_flush = 0;
