[GRASS-dev] Network Analysis
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Fri Sep 4 08:47:20 EDT 2009
Right, I won't touch it then.
It's been a while since I have worked on GRASS GIS
(or any project on this scale), so will have to get
used to proper procedures first...
Ben
Martin Landa wrote:
> Hi,
> 2009/9/4 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
>> I think this should go at least into 6.5.svn for now.
>> We should also think about including Daniel's contribution
>> in 6.4.1.
> agreed with 6.5/7.0, I can't see any point why to include it to 6.4.1.
> GRASS 6.4.1 will be bugfixes release, such release should not
> introduce any new features.
>> It seems misplaced in the add-ons repository as it
>> covers some core functionality (and would go nicely
>> with the other v.net.* modules already in base).
> Not really, GRASS Addons is used for Goggle SoC by default. After some
> time results of such projects can be merged into main GRASS
> repository. I suspect to see Daniel's work in trunk till the end of
> the year.
>> If there are no major concerns, I will integrate the
>> code into 6.5 svn. But I don't know enough about
> I would vote to postpone the integration to October (let's say). At
> least there should be a plan for that. In the case of Goggle SoC
> project the integration should be done by mentor after discussion with
> the student (in case of v.krige, the integration is planned for
> November).
> Martin
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
