[GRASS-dev] Re: suspicious warnings while compiling GRASS trunk
(r38973)
Ivan Shmakov
oneingray at gmail.com
Sun Sep 6 06:04:03 EDT 2009
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
Thanks for a timely response!
>> make[3]: Entering directory `/.../grass-trunk-r38973/raster/r.li/r.li.shape' map.c:344: warning:
>> cast to pointer from integer of different size
> The named file doesn't exist in this directory.
Oops! I'll try to re-build a fresh SVN trunk without `-j N' a
bit later.
FSF associate member #7257
