[GRASS-dev] OSX Snow Leopard problem with python
William Kyngesburye
woklist at kyngchaos.com
Mon Sep 7 11:22:56 EDT 2009
On Sep 7, 2009, at 9:16 AM, Markus Neteler wrote:
> On Mon, Sep 7, 2009 at 1:28 AM, William
> Kyngesburye<woklist at kyngchaos.com> wrote:
>> I had some problems getting wxpython GUI to run after upgrading to
>> OSX 10.6
>> Snow Leopard. I thought I might need to rebuild (I was using the
>> Leopard
>> binaries), but that doesn't help.
>> When I got GRASS to execute to correct Python (another issue I know
>> how to
>> workaround), starting the GUI does nothing. With DEBUG level 5, I
>> get:
>> GRASS 6.5.svn (spearfish60):~ > g.gui wxpython
>> D1/5: Attempting to start 'wxpython' GUI ...
>> D3/5: forking 'python' ...
>> re-executing using pythonw
>> And the GUI never appears.
> I have tried here on Mandriva 64bit
> GRASS 6.5.svn (patUTM32):~/grass65 > g.gisenv set=DEBUG=5
> GRASS 6.5.svn (patUTM32):~/grass65 > g.gui wxpython
> Same thing - old map appears, disappears and that's it.
I don't even get anything that appears, just quiet.
> On Mon, Sep 7, 2009 at 5:37 AM, William
>> After some tinkering, I found that the utils.reexec_with_pythonw()
>> is not
>> working. I was able to manually run the GUI by commenting the
>> utils.reexec_with_pythonw() lines in wxgui.py and menuform.py and
>> starting
>> the gui with
>> pythonw "$GISBASE/etc/wxpython/wxgui.py"
> I see it only in wxgui.py:
> Index: wxgui.py
> --- wxgui.py (revision 39055)
> +++ wxgui.py (working copy)
> @@ -1608,7 +1608,7 @@
> # reexec for MacOS
> - utils.reexec_with_pythonw()
> + #utils.reexec_with_pythonw()
> # process command-line arguments
> Unfortunately it does not help.
menuform.py is in gui_modules subfolder. I didn't see that one at
first also, and the GUI didn't start until I fixed both of them.
> I see http://trac.osgeo.org/grass/ticket/594
> which seems to be related.
> Perhaps some more magic is needed (bad URL with spaces)?
> http://wiki.wxpython.org/Automatically Calling pythonw on Mac OS X
(hehe, and Mail's automatic URL recognition stopped at 'Automaticaly')
No spaces, or other odd chars, in the path to pythonw or GRASS.
I wonder if there is just something wrong with that reexec function
definition, since you have a similar problem on Linux (where it never
attempts the exec).
A couple other oddities I noticed:
- menuform.py has a shebang (and hardwired to /usr/bin/python), but
it's only ever imported
- the reexec in menuform.py is redundant
But fixing these didn't help...
And, a potential problem: the reexec doesn't respect the GRASS_PYTHON
setting. g.gui starts using GRASS_PYTHON, but the reexec is simply
'pythonw', which may not be from the same python build. I could even
set GRASS_PYTHON to a specific pythonw, but it will still reexec with
'pythonw'.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
