[GRASS-dev] Re: r.series: threshold/count method?
Hamish hamish_b at yahoo.com
Tue Sep 8 02:05:39 EDT 2009
Markus:
> The problem is the non-linear increase here, I guess: If I
> would check for 1000 GDD in above example, I have the input
> 193,997.8
> 194,1008.4
> but get
> EPSILON = 1e-6
> > abs(997 - 1000) < EPSILON * 1000
> [1] FALSE
> > abs(1008.4 - 1000) < EPSILON * 1000
> [1] FALSE
> and still won't find it.
the correct output here is "194", yes? ie the first day to cross that
threshold? Can you guarantee that the input data array is sorted?
why worry about EPSILON at all? If sorted:
for(i=0; i < data.n; i++)
   if ( data.val[i] > threshold )
      return data.day[i];
If not sorted just run through the whole loop and
first_day=366;
for (day)
 if ((val > thresh) && (day < first_day))
    first_day = day;
return first_day;
Hamish
