[GRASS-dev] error ./configuring trunk
Hamish
hamish_b at yahoo.com
Tue Sep 8 16:49:26 EDT 2009
with latest svn when I try to ./configure trunk I get a whole pile of
sed usage errors:
checking whether to use Python... yes
checking for python-config... /usr/bin/python2.5-config
checking for Python.h... yes
sed: invalid option -- E
Usage: sed [OPTION]... {script-only-if-no-other-script} [input-file]...
-n, --quiet, --silent
suppress automatic printing of pattern space
-e script, --expression=script
add the script to the commands to be executed
-f script-file, --file=script-file
add the contents of script-file to the commands to be executed
-i[SUFFIX], --in-place[=SUFFIX]
edit files in place (makes backup if extension supplied)
-l N, --line-length=N
specify the desired line-wrap length for the `l' command
--posix
disable all GNU extensions.
-r, --regexp-extended
use extended regular expressions in the script.
-s, --separate
consider files as separate rather than as a single continuous
long stream.
-u, --unbuffered
load minimal amounts of data from the input files and flush
the output buffers more often
--help display this help and exit
--version output version information and exit
If no -e, --expression, -f, or --file option is given, then the first
non-option argument is taken as the sed script to interpret. All
remaining arguments are names of input files; if no input files are
specified, then the standard input is read.
E-mail bug reports to: bonzini at gnu.org .
Be sure to include the word ``sed'' somewhere in the ``Subject:'' field.
--posix
creating ./config.status
creating include/Make/Platform.make
creating include/version.h
creating swig/perl/Makefile.PL
creating swig/perl2/make.pl
creating grass.pc
creating include/config.h
Copying config.status to config.status.x86_64-unknown-linux-gnu
GRASS is now configured for: x86_64-unknown-linux-gnu
Python support: yes
It seems to build ok except for wxVdigit, wxNviz, and xganim.
Hamish
