[GRASS-dev] error ./configuring trunk
Tue Sep 8 21:44:50 EDT 2009
William Kyngesburye wrote:
> Oops, I think it's the OSX arch options I added this weekend - they
> use the -E sed flag that's in BSD sed, but maybe not in GNU sed?  I
> wasn't sure if I should (or how) to only check those parts on OSX (it
> does NOT have anything to do with the OSX app option).  Or is there an
> equivalent -E option that works in GNU and BSD?
> Is it OK to check the $system var in configure.in, when it's something
> that's created by an autocof macro?  Or is there an AC macro that can
> do something based on the system?
You should probably use AC_CANONICAL_BUILD and $build, as that
specifies the platform on which the package is being built.
It doesn't make much difference right now, as cross-compilation is
broken, but that might get fixed in the future.
