[GRASS-dev] Re: [GRASS GIS] #744: package.sh for compiling on windows
GRASS GIS trac at osgeo.org
Wed Sep 9 15:46:04 EDT 2009
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.5.0
 Component:  Compiling        |     Version:  svn-develbranch6
Resolution:                   |    Keywords:  wingrass
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by cnielsen):
 I've updated the CompileOnWindows wiki page to reflect recent updates to
 package.sh. Look at the GRASS-6.4.0 section and adapt the line numbers for
 develbranch_6.
 The default paths were from Jurgen, but as hamish noted in a comment in
 r39046, these should probably be changed to be more general.
 %PROGRAMFILES% wouldn't be so good because of continuing issues with
 paths-with-spaces, but maybe it should be changed to /c/osgeo4w/ to
 reflect the suggested path in CompileOnWindows?
 I added instructions to remove the {{{-j4}}} from the make command because
 I got errors, similarly with the bottom half of the script which is
 designed to build osgeo4w packages (using VC) and isn't needed for normal
 builds... but maybe I'm missing something.
Ticket URL: <http://trac.osgeo.org/grass/ticket/744#comment:2>
