[GRASS-dev] [GRASS GIS] #747: v.rast.stats to table connected to layer 2 fails
GRASS GIS trac at osgeo.org
Thu Sep 10 09:40:11 EDT 2009
 Reporter:  pvanbosgeo   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  default      |     Version:  svn-develbranch6
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 I am using v.rast.stats, which works fine when using the default attribute
 table (layer 1). When however I specify the layer to which the table to be
 changes is connected to be layer 2 it goes wrong. Basically (1) the
 columns are added to the table linked to layer 1 instead of the table
 linked to layer 2 and (2) the columns remain empty.
 Best regards
 Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/747>
