[GRASS-dev] some impressions on the wx interface
Glynn Clements
glynn at gclements.plus.com
Fri Sep 11 21:14:08 EDT 2009
Michael Barton wrote:
> > And as I said before - I am missing the d.* commands sooo much!
> The old d.* commands will not work in GRASS 7...at all because of the
> change in the underlying display architecture.
The commands work fine; they just behave differently in terms of where
the resulting image ends up.
> Remember, they dumped displays to a generic X window.
They generated output via the current monitor, which may or may not
have been an X monitor.
> To get an image into a canvas (TclTk
> or wxPython) is considerably more complicated, though you can do a lot
> more with it once it's there.
> The reason for the message is that Jachim Czpicky originally, and
> Martin Landa subsequently have thought about the possibility of having
> the command parser recognize a d.* command and display the result in a
> wxpython canvas.
Trying to recognise d.* commands prior to execution is unwise; e.g.
this probably won't work if the command is a user script which invokes
d.* commands.
It would make more sense to assume that any command may generate
output, and to allow for this by setting all relevant environment
variables.
> This sort of works in the Mac and Unix from the
> wxpython command parser, but I don't think that the python scripts to
> do this from a terminal are functional (Martin can correct me on this
> if I'm wrong).
> However, it seems to me better to wait until the display architecture
> is more finalized in GRASS 7 to do this.
I'm unaware of any planned changes to the way that the display library
works. I'm not anticipating any significant changes, although specific
features can be added if necessary.
