[GRASS-dev] suspicious warnings while compiling GRASS trunk
(r39080)
Glynn Clements
glynn at gclements.plus.com
Sat Sep 12 19:32:36 EDT 2009
Markus Neteler wrote:
> I have backported the relevant changes but I am unsure
> about
> r39134, Attempt to determine message encoding on Windows [relevant for R]
I think that this should be back-ported. Otherwise, I can't see
--with-nls working on Windows, as --interface-description will
generate invalid XML.
> r39136, Fix diglib warnings
These mostly fix warnings related to Markus Metz' LFS changes, so
shouldn't be applicable to 6.4.
