[GRASS-dev] r38992 Vect_get_num return long
Markus Metz
markus.metz.giswork at googlemail.com
Sun Sep 13 07:40:38 EDT 2009
AFAIKT, r38992 Vect_get_num return long has no effect because the number
of features (for each type) is stored as plus_t which is int. If you
want to prepare the vector libs to support more than INT_MAX objects, I
would suggest to use
plus_t Vect_get_num_primitives(const struct Map_info *, int);
etc and then think about what type is appropriate for plus_t.
I would suggest *not* to use long because long is the same like int on
32 bit (4 bytes) and the same like long long int on 64 bit (8 bytes),
i.e. a vector written with 64 bit may not be readable with 32 bit which
is against all the efforts to keep the vector format independent of
platform/architecture/compiler. Some unsigned integer type should work,
else some checks would be needed similar to what Glynn recently
implemented to get an integer type of size 8 in port_init.c. E.g. use
long if possible else use long long if possible else fatal error, no
integer of size 8 available (or is there something else that could have
a size of 8 ?).
Markus M
