[GRASS-dev] r38992 Vect_get_num return long
Glynn Clements
glynn at gclements.plus.com
Mon Sep 14 11:00:10 EDT 2009
Markus Metz wrote:
> AFAIKT, r38992 Vect_get_num return long has no effect because the number
> of features (for each type) is stored as plus_t which is int. If you
> want to prepare the vector libs to support more than INT_MAX objects, I
> would suggest to use
> plus_t Vect_get_num_primitives(const struct Map_info *, int);
> etc and then think about what type is appropriate for plus_t.
> I would suggest *not* to use long because long is the same like int on
> 32 bit (4 bytes) and the same like long long int on 64 bit (8 bytes),
> i.e. a vector written with 64 bit may not be readable with 32 bit which
> is against all the efforts to keep the vector format independent of
> platform/architecture/compiler. Some unsigned integer type should work,
> else some checks would be needed similar to what Glynn recently
> implemented to get an integer type of size 8 in port_init.c. E.g. use
> long if possible else use long long if possible else fatal error, no
> integer of size 8 available (or is there something else that could have
> a size of 8 ?).
#ifdef HAVE_LONG_LONG_INT
typedef long long longest;
#else
typedef long longest;
#endif
If you're desperate for more than 32 bits, an IEEE "double" can
represent integers between -2^53 and 2^53 exactly, but this is likely
to be more trouble than it's worth (you have to be careful with
division, you can't use a double as an array index, you can't use
shifts or bitwise operators, ...).
