[GRASS-dev] r38992 Vect_get_num return long
Glynn Clements
glynn at gclements.plus.com
Tue Sep 15 01:08:51 EDT 2009
Markus Metz wrote:
> > #ifdef HAVE_LONG_LONG_INT
> > typedef long long longest;
> > #else
> > typedef long longest;
> > #endif
> > If you're desperate for more than 32 bits, an IEEE "double" can
> > represent integers between -2^53 and 2^53 exactly, but this is likely
> > to be more trouble than it's worth (you have to be careful with
> > division, you can't use a double as an array index, you can't use
> > shifts or bitwise operators, ...).
> IMHO, we should first make sure that the vector libs support up to
> INT_MAX (2^31 - 1) features. Vector libs LFS was a first step, and
> unless there is a revolutionary new hardware concept in the near future
> with huge amounts of RAM and much higher processing speed, building
> topology for so many features will take a long long time, particularly
> in case of areas. One solution would be to increase the speed and
> decrease the memory requirements of topology building, and I think more
> brains should be put to that task before increasing the number of
> supported features, i.e. changing plus_t from a 32-bit integer type to a
> 64-bit integer type.
It isn't just vector code which would benefit from a wide integer
type. Some raster code has problems with maps with more than 2^31
cells.
