[GRASS-dev] Re: [GRASS GIS] #608: GIS.m: Lat/Lon support broken in
Map Display zooms
trac at osgeo.org
Tue Sep 15 09:37:09 EDT 2009
#608: GIS.m: Lat/Lon support broken in Map Display zooms
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: blocker | Milestone: 6.4.0
Component: Tcl | Version: svn-develbranch6
Resolution: fixed | Keywords: gis.m, LL
Platform: All | Cpu: All
Changes (by hamish):
* cc: hamish_b at yahoo.com (removed)
Comment:
> If you try repeatedly to zoom out beyond the maximum latlon
> (i.e., beyond 90N or 90S), the behavior is unpredictable.
mmmph. that's what I was trying to address with the if(y>90)y=90; stuff.
Instead of that maybe it could just invoke pan mode or return with the
same bounds as it started with?
> Please test. If it is satisfactory, it can be backported to 6.4.
sure. I'm using the etopo2 dataset for testing. (see grass wiki global
datasets page)
fyi- if you are the reporter or have commented to the bug report you are
automatically added to the cc list. Also if adding to the cc list it is
better to use the osgeo ID than full email addr, as exposing that just
adds to the spam load..
thanks for taking this one on,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/608#comment:5>
