[GRASS-dev] wxgui problem (grass -r 39224 linux x86_64 "sidux" )
Massimo Di Stefano
massimodisasha at yahoo.it
Wed Sep 16 14:24:19 EDT 2009
i'm compiling grass from svn source using the 6.5 version,
i'm on a debian sid derived distro "sidux"
i used this configure to build grass :
CFLAGS="-ggdb -Wall -Werror-implicit-function-declaration" ./configure
--with-tcltk-includes=/usr/include/tcl8.5/ \
--with-freetype --with-freetype-includes=/usr/include/freetype2/ --
with-cxx --enable-64bit --with-geos --with-ffmpeg \
--with-mysql --with-postgres --with-postgres-includes=/usr/include/
postgresql/ --with-mysql-includes=/usr/include/mysql/ \
--with-ffmpeg-includes=/usr/include/ffmpeg/ --with-odbc --with-python
--with-sqlite --with-wxwidgets=/usr/bin/wx-config \
--with-readline --enable-largefile --with-proj-share=/usr/share/proj --
with-cairo --with-motif
wx-config --version-full
give me :
2.8.7.1
i used :
g.gisenv set="DEBUG=5"
Tring to tun the wxgui it starts without errors, but try to add a
raster map in the canvas, i'm not able to display it
zoom to selected map do nothing, and the coordinates under the mouse
movment are not displayer
in the output window i can see this log details :
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
pdisp_window.py", line 450, in OnPaint
self.pdc.DrawToDCClipped(dc, rgn)
File "/usr/local/grass-6.5.svn/etc/wxpython/vdigit/grass6_
wxvdigit.py", line 393, in DrawToDCClipped
def DrawToDCClipped(self, *args): return
_grass6_wxvdigit.PseudoDC_DrawToDCClipped(self, *args)
TypeError
in method 'PseudoDC_DrawToDCClipped', argument 2 of type
'void *'
pdisp_window.py", line 542, in OnIdle
self.UpdateMap(render=True)
pdisp_window.py", line 667, in UpdateMap
self.Draw(self.pdc, self.img, drawid=id)
pdisp_window.py", line 271, in Draw
pdc.SetBackground(bg)
wxvdigit.py", line 384, in SetBackground
def SetBackground(self, *args): return
_grass6_wxvdigit.PseudoDC_SetBackground(self, *args)
TypeError
in method 'PseudoDC_SetBackground', argument 2 of type
'wxBrush const &'
pdisp_window.py", line 2510, in OnZoomToMap
self.ZoomToMap()
pdisp_window.py", line 2561, in ZoomToMap
self.UpdateMap()
TypeError
'wxBrush const &'
self.ZoomToMap()
self.UpdateMap()
TypeError
'wxBrush const &'
pdisp_window.py", line 1017, in MouseActions
self.OnLeftUp(event)
pdisp_window.py", line 1809, in OnLeftUp
TypeError
'wxBrush const &'
TypeError
'wxBrush const &'
TypeError
'wxBrush const &'
TypeError
'wxBrush const &'
pdisp.py", line 628, in OnRender
self.MapWindow.UpdateMap(render=True)
TypeError
'wxBrush const &'
TypeError
'wxBrush const &'
TypeError
'wxBrush const &'
i also tried to run g.gui wxpython using "strace", i had :
strace g.gui wxpython
execve("/usr/local/grass-6.5.svn/bin/g.gui", ["g.gui", "wxpython"], [/
* 48 vars */]) = 0
brk(0) = 0x10e5000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0) = 0x7fbb6b49b000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or
directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0) = 0x7fbb6b499000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or
directory)
open("/usr/local/grass-6.5.svn/lib/tls/x86_64/libgrass_gis.so",
O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/local/grass-6.5.svn/lib/tls/x86_64", 0x7fff6647d510) = -1
open("/usr/local/grass-6.5.svn/lib/tls/libgrass_gis.so", O_RDONLY) =
stat("/usr/local/grass-6.5.svn/lib/tls", 0x7fff6647d510) = -1 ENOENT
open("/usr/local/grass-6.5.svn/lib/x86_64/libgrass_gis.so", O_RDONLY)
stat("/usr/local/grass-6.5.svn/lib/x86_64", 0x7fff6647d510) = -1
I have no clue on how to debug this weird situation, a friend on grass
irc using the same wxpython version on the same grass revision on
ubuntu (i suppose) X86_64
has not problems to run the wxpython gui.
i enabled the debug symbols but i need to learn how to use gdb on the
g.gui executable.
Any suggestion can make me happy!
thanks to All,
Massimo.
(P.S.: apologize me if this mail is sended twice)
Un allegato HTML è stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090916/4c38c6b0/attachment-0001.html
