[GRASS-dev] [GRASS GIS] #752: wxGUI: wrong map layer adjustment for opacity
GRASS GIS trac at osgeo.org
Wed Sep 16 15:14:19 EDT 2009
 Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.0
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:          |    Platform:  Linux
      Cpu:  x86-64  |
 in the wxGUI layer manager windows, if you click on the little Preferences
 button (hey could that be packed on the far right? it would be much
 cleaner) ... while another layer line is highlighted you get a context
 menu. If you select change opacity and change it, the highlighted layer
 row is modified, not the one you right clicked on. If you click on the
 layer map name and not the preferences button it works as expected.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/752>
