[GRASS-dev] Re: nviz won't launch from wx GUI menu in WinGRASS
Michael Barton Michael.Barton at asu.edu
Thu Sep 17 02:09:23 EDT 2009
On Sep 16, 2009, at 10:36 PM, Hamish wrote:
>>> The weird thing is that this DOES seem to work if you
>> launch it from the Msys GRASS terminal in Windows.
> Helena:
>> I can just confirm that nviz reliably works from the MSYS
>> GRASS terminal in MSWindows - we have used
>> it a lot by now, when run from wxGUI it launches it but the
>> TclTk interface does not open
> from the Cmd> prompt in the wx layer manager it fails.
Probably for the same reason that the code in the nviz script fails--
whatever that is.
Michael
> Hamish
