I don't know how to debug this weird problem,
but now i have set grass debug level to 5
and when i open grass in tcltk gui i hade this message :
http://img3.imageshack.us/i/tcltklog.png/
can be usefull to undstand what appens on my computer?
please, thanks for any help!
Massimo.
Il giorno 16/set/09, alle ore 20:31, grass-dev-request a lists.osgeo.org
ha scritto:
> Hi,
> i'm compiling grass from svn source using the 6.5 version,
> i'm on a debian sid derived distro "sidux"
> i used this configure to build grass :
> CFLAGS="-ggdb -Wall -Werror-implicit-function-declaration" ./
> configure --with-tcltk-includes=/usr/include/tcl8.5/ \
> --with-freetype --with-freetype-includes=/usr/include/freetype2/ --
> with-cxx --enable-64bit --with-geos --with-ffmpeg \
> --with-mysql --with-postgres --with-postgres-includes=/usr/include/
> postgresql/ --with-mysql-includes=/usr/include/mysql/ \
> --with-ffmpeg-includes=/usr/include/ffmpeg/ --with-odbc --with-
> python --with-sqlite --with-wxwidgets=/usr/bin/wx-config \
> --with-readline --enable-largefile --with-proj-share=/usr/share/proj
> --with-cairo --with-motif
> wx-config --version-full
> give me :
> 2.8.7.1
> i used :
> g.gisenv set="DEBUG=5"
> Tring to tun the wxgui it starts without errors, but try to add a
> raster map in the canvas, i'm not able to display it
> zoom to selected map do nothing, and the coordinates under the mouse
> movment are not displayer
> in the output window i can see this log details :
> Traceback (most recent call last):
> File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
> pdisp_window.py", line 450, in OnPaint
> self.pdc.DrawToDCClipped(dc, rgn)
> File "/usr/local/grass-6.5.svn/etc/wxpython/vdigit/grass6_
> wxvdigit.py", line 393, in DrawToDCClipped
> def DrawToDCClipped(self, *args): return
> _grass6_wxvdigit.PseudoDC_DrawToDCClipped(self, *args)
> TypeError
> in method 'PseudoDC_DrawToDCClipped', argument 2 of type
> 'void *'
> pdisp_window.py", line 542, in OnIdle
> self.UpdateMap(render=True)
> pdisp_window.py", line 667, in UpdateMap
> self.Draw(self.pdc, self.img, drawid=id)
> pdisp_window.py", line 271, in Draw
> pdc.SetBackground(bg)
> wxvdigit.py", line 384, in SetBackground
> def SetBackground(self, *args): return
> _grass6_wxvdigit.PseudoDC_SetBackground(self, *args)
> TypeError
> in method 'PseudoDC_SetBackground', argument 2 of type
> 'wxBrush const &'
> pdisp_window.py", line 2510, in OnZoomToMap
> self.ZoomToMap()
> pdisp_window.py", line 2561, in ZoomToMap
> self.UpdateMap()
> TypeError
> 'wxBrush const &'
> self.ZoomToMap()
> self.UpdateMap()
> TypeError
> 'wxBrush const &'
> pdisp_window.py", line 1017, in MouseActions
> self.OnLeftUp(event)
> pdisp_window.py", line 1809, in OnLeftUp
> TypeError
> 'wxBrush const &'
> TypeError
> 'wxBrush const &'
> TypeError
> 'wxBrush const &'
> TypeError
> 'wxBrush const &'
> pdisp.py", line 628, in OnRender
> self.MapWindow.UpdateMap(render=True)
> TypeError
> 'wxBrush const &'
> TypeError
> 'wxBrush const &'
> TypeError
> 'wxBrush const &'
> i also tried to run g.gui wxpython using "strace", i had :
> strace g.gui wxpython
> execve("/usr/local/grass-6.5.svn/bin/g.gui", ["g.gui", "wxpython"],
> [/* 48 vars */]) = 0
> brk(0) = 0x10e5000
> mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS,
> -1, 0) = 0x7fbb6b49b000
> access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or
> directory)
> mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS,
> -1, 0) = 0x7fbb6b499000
> access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or
> directory)
> open("/usr/local/grass-6.5.svn/lib/tls/x86_64/libgrass_gis.so",
> O_RDONLY) = -1 ENOENT (No such file or directory)
> stat("/usr/local/grass-6.5.svn/lib/tls/x86_64", 0x7fff6647d510) = -1
> open("/usr/local/grass-6.5.svn/lib/tls/libgrass_gis.so", O_RDONLY) =
> stat("/usr/local/grass-6.5.svn/lib/tls", 0x7fff6647d510) = -1 ENOENT
> open("/usr/local/grass-6.5.svn/lib/x86_64/libgrass_gis.so",
> stat("/usr/local/grass-6.5.svn/lib/x86_64", 0x7fff6647d510) = -1
> I have no clue on how to debug this weird situation, a friend on
> grass irc using the same wxpython version on the same grass revision
> on ubuntu (i suppose) X86_64
> has not problems to run the wxpython gui.
> i enabled the debug symbols but i need to learn how to use gdb on
> the g.gui executable.
> Any suggestion can make me happy!
> thanks to All,
> Massimo.
Rimosso contenuto di tipo multipart/related
