[GRASS-dev] Re: wxgui problem (grass -r 39224 linux x86_64
"sidux" )
Massimo Di Stefano
massimodisasha at yahoo.it
Thu Sep 17 12:53:57 EDT 2009
I tried on a fresh download of NC dataset, i get the same problem.
i also tried to create a new location but the problem persists.
when i close the wxpython gui i can read this message on the grass
shell :
(python:23309): Gdk-CRITICAL **: gdk_draw_drawable: assertion
`GDK_IS_DRAWABLE (drawable)' failed
Il giorno 17/set/09, alle ore 16:14, Hamish ha scritto:
> Massimo wrote:
>> The problem i had is building the grass6_devel branch (grass-6.5.svn)
>> I'll try to figure out on how to apply the patch on grass65
>> I tried to compile the grass64-rc and it works fine in both tcltk and
>> wx gui.
> oh ok. If it is a recent svn checkout you don't need the patch.
> no sure what it would be then. try creating a new location from
> scratch and see if it still happens?
> Hamish
