[GRASS-dev] Re: [GRASS GIS] #594: wx GUI won't start (Mac OS X
10.5.6) / Python 2.6 / wxWidgets 2.8.10 / wxPyhton 2.8.9.2
trac at osgeo.org
Sat Sep 19 01:02:27 EDT 2009
#594: wx GUI won't start (Mac OS X 10.5.6) / Python 2.6 / wxWidgets 2.8.10 /
wxPyhton 2.8.9.2
Reporter: vince | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wxGUI does not load
Platform: MacOSX | Cpu: x86-64
Comment (by cmbarton):
I'm pretty sure that this is now fixed. No problem now with Mac starting
as described. But there may be a related problem. The wxPython GUI only
seems to start now if the user has <b>exactly</b> the same version that it
was compiled with.
It should run with all versions of wxPython above 2.8.0, but if I compile
with 2.8.9.2, it only runs with 2.8.9.2. Otherwise it generates a bad
version error.
Is this a different issue (needing its own ticket) or another
manifestation of the issue described here?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/594#comment:8>
