[GRASS-dev] Re: grass-dev Digest, Vol 41, Issue 61
Massimo Di Stefano massimodisasha at gmail.com
Sun Sep 20 05:08:27 EDT 2009
Hi
Il giorno 20/set/09, alle ore 02:11, Martin Landa <landa.martin
gmail.com> ha scritto:
> Oggetto: Re: [GRASS-dev] wxgui problem (grass -r 39224 linux x86_64
> "sidux" )
> Hi,
> 2009/9/19 Massimo Di Stefano <massimodisasha at gmail.com>:
>> my swig version is :  1.3.39
> yes, that's same here - I use Debian Sid and wxpython from packages
> apt.widgets.org. In this case wxPython is build probably with 1.3.36.
i'm on a debian sid derived distro, using the official debian-sid
repository
what's wour source.list line to add the wx widjet repository ?
i have found this page :
http://wiki.wxpython.org/InstallingOnUbuntuOrDebian
but there is no "sid" only lenny or "etch", shoul'd be good this one,
using etch ? :
# wxWidgets/wxPython repository at apt.wxwidgets.org
     deb http://apt.wxwidgets.org/ etch-wx main
     deb-src http://apt.wxwidgets.org/ etch-wx main
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090920/e8fd3d55/attachment.html
