[GRASS-dev] Re: [GRASS GIS] #754: Deep Vector Bug: Overlay
functionality flawed in v.select and v.in.ogr
trac at osgeo.org
Mon Sep 21 08:06:36 EDT 2009
#754: Deep Vector Bug: Overlay functionality flawed in v.select and v.in.ogr
Reporter: ploewe | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.5.0
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords: v.overlay
Platform: Linux | Cpu: Unspecified
Comment (by ploewe):
Replying to [comment:2 mmetz]:
> Replying to [comment:1 martinl]:
> > > Sample data / Screenshots can be produced on request.
> > Yes, please attach sample data e.g., in GRASS ASCII vector format.
> +1, if the sample data are too large for attachment, please send them
off-list as attachment.
> Could you also provide information about what were the exact commands
you used, what do you want to happen with the overlapping areas i.e. which
cleaning operations should be performed, and what should the desired
result look like.
> Thanks,
> Markus M
Done.
Two sample input data sets were attached as ESR! shapes to the ticket plus
the result from v.patch as generated by grass6.4R5.
Here's the challenge: The two tile grids provided in the two input
shapefiles partially overlap. The task is NOT to clean the topology (and
to create new sub-polygons in the overlap area), BUT to maintain the
current polygon pattern, which implies that a number of poylgons overlap.
In a naive approach, v.patch was used to accomplish this:
v.patch -e
input=country_germany_tiles_zone33 at aoi,country_germany_tiles_zone32 at aoi
output=patch33_32
Interestingly, the process generates "empty strips" within the resulting
data set: In these zones there are "failed" polygons, for which only
centroids exist.
In the above example (v.patch ... ... output=patch33_32) examine the
centroids/polygons with the categories 27658 and 13692 (or 27640 and
13674).
BTW: The same effect occurs when importing a larger dataset (Shape) into
GRASS with v.in.ogr which includes both UTM strips. Therefore I guess that
the problem isn't module- but library-specific.
Peter
Peter
Ticket URL: <http://trac.osgeo.org/grass/ticket/754#comment:3>
