[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton
Michael.Barton at asu.edu
Mon Sep 21 13:30:18 EDT 2009
Bingo!
Bundling wxPython with GRASS 6.4 produces a binary in which wxPython
digitize works without crashing the GUI.
Now the question is why does this work and a normal make does not--
using the same source file and the same binary wxPython installation.
I will try the same thing with GRASS 6.5 and see if it solves the
frozen elements problem. I take it that I follow the wiki instructions
for 6.5, correct?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 10:09 AM, William Kyngesburye wrote:
> in the source macosx folder.
> On Sep 21, 2009, at 12:01 PM, Michael Barton wrote:
>> Where does the installer package end up? Where do I find it?
>> Michael
>> C. Michael Barton
>> USA
>> On Sep 21, 2009, at 9:57 AM, William Kyngesburye wrote:
>>> make install is does what it always has.
>>> make bindist creates an OSX installer package. It also leaves a
>>> copy
>>> of the program as it was packaged in the installer, in the macosx
>>> source folder (dist subfolder).
>>> On Sep 21, 2009, at 11:43 AM, Michael Barton wrote:
>>>> What is the difference between make install and make bindist?
>>>> Michael
>>>> C. Michael Barton
>>>> Change
>>>> USA
>>>> On Sep 21, 2009, at 8:51 AM, William Kyngesburye wrote:
>>>>> No need to sudo a bindist, it all happens in the source folder.
>>>>> Also, that ${INST_DIR_TARGET} is really ${MACOSX_BUNDLE_PREFIX},
>>>>> like
>>>>> it used to be in the wiki.
>>>>> The copies for the libs probably quietly failed, as there is no
>>>>> root /
>>>>> lib folder. But you may now have a root /etc/python folder now
>>>>> with
>>>>> the wxpython files, which should be deleted.
>>>>> Sorry for the confusion. I wasn't sure if I should backport the
>>>>> install bundling changes to the release 6.4.
>>>>> On Sep 21, 2009, at 10:29 AM, Michael Barton wrote:
>>>>>> I was trying this with 6.4
>>>>>> I've never done a bindist so perhaps I did it wrong. But when I
>>>>>> typed in...
>>>>>> sudo make bindist
>>>>>> ...I got a lot of good looking output and then this:
>>>>>> cp -fp /usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/
>>>>>> site-
>>>>>> packages/wxversion.py /etc/python
>>>>>> sed -i '' -e 's/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/' /grass.sh
>>>>>> sed: /grass.sh: No such file or directory
>>>>>> make[3]: *** [bundle-macosx] Error 1
>>>>>> make[2]: *** [bindist-macosx] Error 2
>>>>>> make[1]: *** [bindist-macosx] Error 2
>>>>>> make: *** [bindist] Error 2
>>>>>> Michael
>>>>>> On Sep 21, 2009, at 8:00 AM, William Kyngesburye wrote:
>>>>>>> Ah, GRASS 6.4 or 6.5? I didn't backport a change to 6.4 so that
>>>>>>> the
>>>>>>> bundling happens in the install. In 6.4 bundling happens only
>>>>>>> for a
>>>>>>> make bindist. In 6.5+ it also happens for an install.
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "The beast is actively interested only in now, and, as it is
>>>>> always
>>>>> now and always shall be, there is an eternity of time for the
>>>>> accomplishment of objects."
>>>>> - the wisdom of Tarzan
>>> "We are at war with them. Neither in hatred nor revenge and with no
>>> particular pleasure I shall kill every ___ I can until the war is
>>> over. That is my duty."
>>> "Don't you even hate 'em?"
>>> "What good would it do if I did? If all the many millions of people
>>> of
>>> the allied nations devoted an entire year exclusively to hating the
>>> ____ it wouldn't kill one ___ nor shorten the war one day."
>>> <Ha, ha> "And it might give 'em all stomach ulcers."
>>> - Tarzan, on war
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
