[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton Michael.Barton at asu.edu
Mon Sep 21 16:23:51 EDT 2009
I've only got wxversion.py, no wx.pth
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262; fax: 480-965-7671
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 1:06 PM, Glynn Clements wrote:
> Michael Barton wrote:
>>> Also, make sure there is only one wx path file in your site-
>>> packages,
>>> that points to your only installed wx.
>> How can I check this path?
> Look for a file along the lines of:
> 	.../python2.5/site-packages/wx.pth
> This will contain the (possibly relative) path of a directory to be
> added to the Python module path.
> E.g. I have:
> 	$ cat /usr/lib/python2.5/site-packages/wx.pth
> 	wx-2.8-gtk2-unicode
> This causes the directory
> 	/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode
> to be added to the module path, so "import wx" loads the file
> 	/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/__init__.py
> However: I'm not sure whether wx.pth is actually relevant if wxversion
> is used, as it modifies sys.path itself.
> Glynn Clements <glynn at gclements.plus.com>
